Ich verkaufe ein Ladedruckregelventil der Marke Pierburg. Gekauft wurde es bei Scara 73. Artikelbeschreibung: Overboost valve different from original one and SS one. It is very faster than the original one (or SS one too) and give you the possibility to follow the ECU boost pressure that your ECU man write in your ECU so you can have a high overboost and a low constant boost to high rpm. It can be fitted on all turbo but it is very important when turbo are bigger than original one. Passt Plug and Play bei einem 1.4 T-Jet. 30 € plus gegebenenfalls Versand.
30
